wiring line 139
52m37Hal
wiring line 139
Post by 52m37Hal »
I have a line numbered 139 and one numbered 139A. I can not find the listing for this wire number. Can anyone help?
Also the 139 wire is connected to a double connector to 25 and 25C. I know that 25 is for the horn but why is it connected to 139 and what is 25C??
knattrass
Post by knattrass »
Hal - my horn runs 25 from the breaker to the horn, 25A out of the horn to 25B/25C running to the horn switch. There are no double connectors in the run but I would suspect that someone jumped a double into it for IGN ON hot lead. We have all of our electrical nailed to 2x4's in the basement for re-wiring. We ended up replacing the horn with a new one.
52m37Hal
Post by 52m37Hal »
Sounds like yours is wired as it should be according to the wiring diagram.
I did find a reference that lists wire # 139 as 'Turret Ground', so, I spent all day looking for my M37's 'turret'....:-)
Go figure...
I will have to trace it out through the wiring harnes.
