Is there a way to test the Crkt Breakers? If so, how?
On the newer breakers with the rubber Packard connections does it matter which end is the power input?
Hal
CRKT Breaker Questions
Thanks.
How do I identify + and - sides on the Packard type breaker. Mine are not labeled and both connectors are the same. This breakes was part of a M-151 heater kit.
Hal
PS I thought the breakers are like a fuse, power in one end, through the fuse or breaker and power out the other end. No ground involved, am i missing something?
Thanks.
Hal
DUH! I was thinking in terms of relays, in which the "hot" wire goes into the coil of an electromagnet.
If the connectors are the same, it probably doesn't matter. If there is one male connector and one female connector, as there should be if installing it in an existing circuit, then you will have to plug it in accordingly.
