Drivetrain noise solved (or, how dumb am I)?
Most of you know I've been pushing on with my M37 project since July 2004. Having had transmission issues, clutch issues, wiring, starter (hey, what HAVEN'T I had to deal with)?! Anyway, I had one pesky drivetrain rattle that I've been unable to resolve, until last Sunday. Since this rattle only appeared when the M was in motion, I was left with no choice but to drop the front drive shaft (transfer case side only, and I use lockout hubs), pull both back tires off and put the rear on two jack stands (with the jack acting as the fail-safe support along with both tires laid flat under the rear crossmember). After securing each drum with two lug nuts, I started the M and went through all four forward gears, and there it was: ting, ti-ting, ting....
Leaving it idling in 4th gear, I grabbed my creeper and went below:
Clutch and release bearing-ok
Transmission-ok (freshly rebuilt)
Transfer case-ok
Rear diff-ok
The culprit? The right-rear inner corner floorboard bolt is too long and the transfer case shift linkage is ting, tinging against it! Oh how foolish (and relieved I am). I backed out that bolt-silence! Buttoned everything back up and took a 3-mile test drive-no problem!
I am relieved to have solved this one without springing for another transfer case (which I just passed on one locally, rolling the dice that I'd find something else wrong instead).
Lessons learned:
1. Don't overlook the small details;
2. Don't let your project beat you-stay after it and think it through when you have a tough problem-you'll eventually get it figured out! :D
rixm37
Post by rixm37 »
Way to go Gary !
It's amazing how many times it is something really simple that is the culprit ! It's hard not too think huge problem at first!! And VERY frustrating. Glad you passed on the other t-case.
Thanks! Credit should go to my spouse of 27 years who took the earlier test drive and said "it sounds like something rubbing, to me..." and of course I blew her off, being the "expert" in the family when it comes to old HMVs--she's laughing now (and relieved that we didn't have to shell out big bucks for a transfer case)!
I Think I Said It Before
Your Bride of 27 years sounds like a "Keeper"!
Way to go Gary, It looks like you made a good choice 27 years ago. :wink:
Indeed I did-thanks Guys! :D
Glad to hear it was a simple fix. Last summer I feared I had a rod knock only to find my front xfer case lever rattling against the trans cover, I did not have my shift lever boot installed yet :)
You're right, David,
All those little noises are spooky when you first get it on the road (as I now am) with the trips getting stretched a little longer and longer as I gain faith that I'm not going to be stranded on the side of the road.
My 2/4 hi/low shifter bracket was so worn out I ended up using a front leaf-spring pin and cut the new bushing in half to do the repair. The bushing fits inside the shifters perfectly, and using the spring pin allows you to use a locking nut to secure it instead of a cotter pin and washer. This keeps the shifters from slopping around. Snug = no rattling around. I'd lose points by the HMV judges but the field mod works as I intended....
