Montana's back-up engine Question...
- PFC
When I put the timing chain on, I noticed something weird. When I started to roll the engine over to double check my timing marks, the intake on No. 1 opened indicating the start of the intake stroke, not the power stroke. So I think that it is really on number 6 TDC, not number 1 TDC. Am I crazy?
If I'm interpreting your post correctly, you are good to go. When the timing marks are aligned next to each other, install the chain. After installation, spin the crank until #1 is at TDC on the compression stroke, the timing sprocket marks will then be 180 degrees apart. Sounds like this is what you have done already, am I making the correct assumption?
- PFC
That would be "psyching," and you probably were.
The timing marks are next to each other when #6 is at TDC on its compression stroke. When the crank is turned 180 degrees (1/2 turn), #1 comes up to TDC on its compression stroke and the timing marks are opposite each other. A straightedge laid across the timing marks should then cross the centers of both the crankshaft and camshaft.
That Dodge 6 did it long before Duntov's small block V8 showed up!
