I am planning on removing my rear hubs to replace seals and inspect. What size socket do I need to remove the hub nut or do you need a special socket for this? Also is there anything special I should be looking for?
Rear hub removal
Rear hub removal
Gerry
53 M37
53 M37
Hub Socket...
You'll need a 2-9/16ths 8 point socket. The hub nuts are the same size on all 4 wheels.
HUB socket
10-4, no problem.
