shackle bushing and bolts
Gerry
Post by Gerry »
Is there a crossover part # for the bolts( center bolt with grease fitting) and bushings for the rear shackles so I can buy local?
Gerry
53 M37
Re: shackle bushing and bolts
Gerry wrote:Is there a crossover part # for the bolts( center bolt with grease fitting) and bushings for the rear shackles so I can buy local?
Bushings can be had and reamed no problem. The bolts are not that way. Must buy original equipment or custom make them.
Gerry
Post by Gerry »
Thanks Charles,
Gerry
53 M37
