turn signal light mounting locations?
- SSGT
Howdy,
I was hoping someone could either post or direct me to images of where the turn signal lights are typically located. I have to add them to my truck to pass inspection. Thanks!
1953 Dodge M43
Fail often to succeed sooner
Re: turn signal light mounting locations?
They are typically incorporated into the park lights on the front & the tail lights on the rear.monkeymissile wrote:Howdy,
- SSGT
Charles,MSeriesRebuild wrote:They are typically incorporated into the park lights on the front & the tail lights on the rear.monkeymissile wrote:Howdy,
so they use the second lamp within those lights meaning I don't have to buy additional lights?
1953 Dodge M43
monkeymissile wrote:Charles,MSeriesRebuild wrote:They are typically incorporated into the park lights on the front & the tail lights on the rear.monkeymissile wrote:Howdy,
The top section of the lamp has 2 bulbs, the larger bulb is used for turn signals & brake lights. On the rear, turn signals & brake lights use the same circuit & bulbs. The small bulb is used for park lights on the front & tail lights on the rear. The bottom section is black out marker lights. The black out brake light is a separate lamp on the rear if using the original set up.monkeymissile wrote:Charles,MSeriesRebuild wrote:They are typically incorporated into the park lights on the front & the tail lights on the rear.monkeymissile wrote:Howdy,
The best military standard signal set up to use is the solid-state system. It is also compatible & interchangable with the current production Signal - Stat 900 series system. The old military type with the huge metal control box is trouble waiting to happen, rare these days, & expensive. Repair parts are getting hard for the older system as well. I would stay away from using that set up.
- SSGT
thanks!
Thanks All,
that really clears things up, appreciate it. Fortunately my truck came with a new ss flasher as one of the spare parts. I was hoping to not have to install it, but looks like I have to in NH.
1953 Dodge M43
Register it in MA if you can
If you are in Boston, register your truck in MA. Here, the only non-original equipment you need is a light over the rear license plate. That way, you don't NEED signals (but I recommend them highly). Here, the rule to pass inspection is that if you have it, it must work.
By the way, if you register in MA, DON'T get the antique plate. Legally, if registered with an antique plate, you can only drive on weekends, to & from shows, and to & from the shop.
- SSGT
Re: Register it in MA if you can
I wish I had the truck down here, but I have no place for it and can't afford a garage so it's in NH at my parent's house for now. I still have to get the brakes working, but after that I might consider it. Thanks for the tip!N1VSM wrote:If you are in Boston, register your truck in MA. Here, the only non-original equipment you need is a light over the rear license plate. That way, you don't NEED signals (but I recommend them highly). Here, the rule to pass inspection is that if you have it, it must work.
1953 Dodge M43
- SSGT
since we're on the topic
I pulled out my instrument panel and noticed that a lot of the wires/connectors need to be replaced. Since my truck didn't come with turn signals originally and I need to add them now, should I get the 5-wire spider harness or do I still use the 4-wire? I have not fully researched how to install the turn signal system into my existing system and wasn't sure if I needed a different harness, etc. Thanks!
1953 Dodge M43
Re: since we're on the topic
If you have bad wiring, the best option you have is to get a whole new harness with turn signal wiring already incorporated into it. You can get a reproduction military harness or build your own. Bad wiring has burned down many a truck, not wise to take risk.monkeymissile wrote:I pulled out my instrument panel and noticed that a lot of the wires/connectors need to be replaced. Since my truck didn't come with turn signals originally and I need to add them now, should I get the 5-wire spider harness or do I still use the 4-wire? I have not fully researched how to install the turn signal system into my existing system and wasn't sure if I needed a different harness, etc. Thanks!
- SSGT
[quote
If you have bad wiring, the best option you have is to get a whole new harness with turn signal wiring already incorporated into it. You can get a reproduction military harness or build your own. Bad wiring has burned down many a truck, not wise to take risk.[/quote]
I've already inquired with Vintage Wiring about a new harness; I have quite a few pennies to save for that, but I agree it's the best way to go. Fortunately I have a cut-off switch at the batteries that I always use.
1953 Dodge M43
- SSGT
