pto question
TOM R
pto question
Post by TOM R »
ok we got the nos case and I want to swap over the parts to get this finished but I need the 2 seals for the lower half is there a napa #? or do i have to goto a m37 dealer?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
Ummmm...where can I even find a "M37 dealer?" ;)
If I do find one, whats the NADA trade-in value of a '54 M37 when trading it for a '09 model? ;)
TOM R
Post by TOM R »
smrt a$$ lol I meant parts dealer :P
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
TOM R wrote:smrt a$$ lol I meant parts dealer :P
We have parts for the PTO.
TOM R
Post by TOM R »
oops dad just found the pto gasket and seal kit in the parts box in the truckbed, is there a tutorial on the pto rebuild?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
TOM R wrote:oops dad just found the pto gasket and seal kit in the parts box in the truckbed, is there a tutorial on the pto rebuild?
Not up to date on any tutorial that may exist. I do know after rebuilding many; there are some issues involved in the PTO overhaul in order to get a long running, leak free rebuild. A good thing to remember is this; a part of the PTO gearing is running at all times that the transmission is in motion. This applies even when the transmission & the PTO are in the neutral positions. I say this to stress the utmost importance of doing a top notch rebuild on this component so you don't have a forever dripping component that can be the cause of later issues with the PTO unit itself & is also directly associated with the transmission.
Experienced gear box rebuilding is something you learn has lots of little nitches along the way over time about how to do things that are not covered in any manual. While manuals are a great & necessary tool if you haven't done it before; manuals talk you through a sequence of events necessary to assemble a unit, lots of other small issues that will keep you out of trouble & give you a successful, long lasting rebuild in the end are never brought to light in manual instructions.
Another issue is old or NOS seals. Good advice is don't use them. NOS or old production seals are certainly no good as with age they have deteriorated to the point of no return. Get current production fresh seals if you want a good job. Also, remember to closely check all seal mating surfaces, if you have pits from rust or wear grooving, it will still leak oil no matter how good the seals. Closely check shafts & case bores that are interference fits for roundness & true fits, off key tolerances in these areas will only be trouble & mean a re-do. These intererference fits must also be sealed correctly using the right sealers or oil will eventually find its way out past them. You will learn quickly when dealing with gear boxes that oil leaks don't always originate from areas that involve oil seals & gaskets.
I'll be glad to talk with you concering lessons we have learned along the way if you would care to call the shop next week.
TOM R
Post by TOM R »
ok thanks charles :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
TOM R
Post by TOM R »
charles can you pm or email me your # thanks thejerk67@comcast.net :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
TOM R wrote:charles can you pm or email me your # thanks thejerk67@comcast.net :D
Shop phone is 704-474-4683
TOM R
Post by TOM R »
ok thanks i will try to give you a call tomorow :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
