Vacuum wipers,
Wayne64
Vacuum wipers,
Post by Wayne64 »
A while ago I posted about a loss of vacuum up at the motors. I had a chance today and did some testing with compressed air. The blockage is in the tube that passes through the windshield hinge. I have the CD manuals and couldn't get either a clear photo or a description on taking the fittings apart. Could someone explain the parts involved and the disassembly of the tube and fittings. TIA
powerwagontim
Post by powerwagontim »
Hi Wayne,
THe fitting on my 51 iwas a brass block with steel lines. The lines were shot, but I soldered in some 1/4" copper tubing I had. My parts truck had a steel block with steel lines. Also frozen into the pivot bolt. There is no mechanical connection, it just slides into the pivot bolt and I suppose the vacuum line inside helps keep it in place. There are a couple of little clips on the windshield hinge, but thats about it. I would pull it out and try soldering new tubes onto it.
Tim
Wayne64
Post by Wayne64 »
Thanks Tim, Here I was over thinking how it worked. I figured the windshield bracket had some kind of gland nut or O-ring. The next sunny day I'll pull it out and check it out.
Replacement windshield bolts are becoming hard to find-try repairing yours if you can.
AB Linn
Hey Tim, Wayne & Gary,
He had them a while back, If he's out I might have a spare somewhere? :idea:
Wayne64
UPDATE!!!
Post by Wayne64 »
Mystery solved. Today was the day I removed the vacuum lines that travel through the windshield hinge. Now under stand I'm just a bit more than disabled and the plate in my neck makes it tough to get under the dash. I try to pull off the vacuum hose from under the dash by feel only, the hose wouldn't even twist with a plier? I had already bought 25' of new 7/32 vacuum hose and again by feel sliced the hose length wise so I could remove it. When I finally got the metal tube assembly removed I saw two things. The tube that traveled through the hinge bolt was copper, OK but it was 3/16" OD instead of 1/4" OD. So the Duck Egg that did the restore put a load of rubber cement on the copper tube and pushed on the hose. I found a perfect plug of rubber cement inside the 3/16" copper tube not to mention the copper tube wasn't even reamed after being cut. I'll check my stock to see if I have some 1/4" OD S.S. tube for a redo. Thanks Gents
powerwagontim
Hi Wayne,
Congrats on getting it fixed! Some of the things we find working on these trucks really make you shake your head in disbelief.
Tim
knattrass
Post by knattrass »
Wayne - working under the dash requires a small teenager who can bend and take the knocks to the head.... I ended up drilling out the steel tube that was rusted into the w/s bolt hole and started over. We switched over to the 24v and passed 2 wires thru the hole and up into the w/s since my son was going to be driving it. I plan on getting my trico's rebuilt and buying the tubing/fitting kit from John at MWM. The 24v wipers are not up to par as Charles has previously posted - but they work in a pinch.
