Gents,
Other than OEM/Mil-spec replacement parts made in rubber, is there anything anyone has used to mount sheet goods to frames of their trucks they prefer?
Nothing wrong with the rubber parts, however I live in desert, rubber tends to loose its vitality quickly in the heat/cold cycles we have here in NE Oregon.
I would be interested in hearing and seeing others solutions.
kevinL
Tub and bed mounting material choices?
'52 M-37 "Rusty Red" parted
Original Stuff
I am not sure, but wasn't the original material canvas belting that was rubberized? Kevin what about canvas belting & silicone? Maybe Sid or John Bizal will log-on to this one?
- HingsingM37
I am making mine out of a piece of coveyor belting. It is reenforced with clth and pretty tough. I plan to use a hole saw to cut rounds out of the sheet. Then drill a center hole. It looks very simlilar to what I removed. I have a 6 foot x 12"piece and would be happy to send you a sample if you wish to go this route.
Gents,
Belting was my "next second best guess" for making the mounts. Seen good pictures where others have fabbed up some decent parts.
What I've seen out here in sun-dried farmlandia is that belting takes a heckova beating, rubber portions tend to wear, then crack, 'go away' long before they actually wear out.
Beastie and I took Old Blue and Rusty Red apart, all the mounts were tired with age and time. What I am looking for is something that will last and be road grime/oil/road gunk/dirt proof.
If belting worked for your projects and sleds then I'll re-look over it, see what is findable out here.
Thnx!
kL
Thnx!
kL
New Products
I'm wondering what they use on new truck beds, they gotta use something? I am getting ready to replace mine as well, so this is timely 4 me.
TTYL,
TTYL,
This 's What I Found
Check this out, let me know what you guys think?
http://www.energysuspensionxd.com/catalog/fruehauf.html
