Anybody ever install a heater in a M37???
- Tim Powell
- MSGT
Hey Folks! I just bought my M37 and had no clue there was no cab heater!! I bought this rig to drive but need heat on my feet!!
Welcome aboard Tim and Lori! You have stumbled onto M37 gold-anything you want or need to know about your truck can be found here! For your heater issue, some use a Mutt heater (from an M151) while others use the fender-mounted heater that is hard to come by, and pricey!
I used a Mutt heater and it works fine (be sure you read the extensive post about Nick's heater hose valves, too!
Search the Archives as well-I found this link from a few months back:
http://www.g741.org/PHPBB/viewtopic.php?t=1241
Again, Welcome!
Again, Welcome!
- Tim Powell
- MSGT
Thank You Gary!!
I can tell I have a lot to learn! Thanks for your reply!! Glad to be here!!
- W_A_Watson_II
I installed a Heater Craft 401HC Hydronic Heater (http://www.heatercraft.com) under my drivers seat on my M, and I'll tell you that it combined with the V-8 will burn your feet off.
Took it out last night, and at ~18 degrees and running 55 MPH i had to turn the fan down to Med.
- Tim Powell
- MSGT
Ah Yes!! Thank you!!
Thank you W A Watson! I am familiar with heatercraft as we have on in our boat!! I believe this is the way I'll go forward. I also think I have found the spots on the engine and radiator hose to attach the heater hoses!! I'll be gone for a week starting tomorrow but I'll be back! Thank you Fellows for all the help!!
Does this heater rely on hot water from the engine, or does it use some sort of heated electrical coil to heat the air? Under the driver's seat is a cool place for a heater, but if you have to run water lines to there, it would seem a bit tricky....W_A_Watson_II wrote:
- W_A_Watson_II
Defroster duct
After you work out a heater, you will most likely find you also need a defroster duct (that is unless you can drive without breathing
). My truck came with a defroster made of 2" dia. pipe with holes drilled along the length, along with other "mods" (pronounced "hacks"). It was worthless. I simply replaced the defoster with the "original" one (4" ducting) and the decreased flow resistance makes a HUGE difference. I no longer have to carry a squeege (for the inside of the windows) with me when I drive.
I may have some misc heater parts that you can use. If you are interested, PM or email me off board & we'll talk.
