inner axle seals
inner axle seals
to change my inner axle seals in my front axle do i have to drive the seal from the inside out to remove? i noticed when i removed the axle shaft that the seal was behind a brass bushing out towards the end of the axle tube.
Firefighters still make house calls.
- sbaumgartner
inner axle seals
so even with the bushing in front of it the slide hammer did the job? i'll have to buy or borrow a slide hammer then. i was going to fit sections of pipe from one side to the other. your way sounds easier!
- sbaumgartner
Slide hammer is the key, but a better option is with a 2 jaw expandable puller attachment instead of the finger type. Some of these seals & bushings are really tight. The expandable jaw type prevents slip offs & really is easier to use for this job, especially since you are pulling bushings & seals in the same operation.
inner axle seals
thanks for the tips guys. this will give me something to do monday!
