Moderators: Cal_Gary , T. Highway , Monkey Man , robi
Posts: 1458 Joined: Sat Oct 20, 2007 3:43 am
Post
by HingsingM37 » Fri Dec 26, 2008 6:38 am
I need to know the center distance between the clevis holes on each end for the clutch pedal linkage and the OAL. I am making a new one and my old piece is bent and looks to have been "modified" by somebody trying to get more pedal height by welding in a bolt.
Posts: 2832 Joined: Sat Oct 20, 2007 4:35 am
Post
by MSeriesRebuild » Fri Dec 26, 2008 11:35 am
HingsingM37 wrote: I need to know the center distance between the clevis holes on each end for the clutch pedal linkage and the OAL. I am making a new one and my old piece is bent and looks to have been "modified" by somebody trying to get more pedal height by welding in a bolt.
If yours is a stock set up, I can send you a good take-off. These pile up around here as we don't use that piece with a Cummins repower.
Post
by HingsingM37 » Fri Dec 26, 2008 12:33 pm
That would work Charles. Thanks.
Post
by MSeriesRebuild » Fri Dec 26, 2008 12:58 pm
HingsingM37 wrote: That would work Charles. Thanks.
Is your mailing address the same as the Fed-Ex address?
Post
by HingsingM37 » Sat Dec 27, 2008 4:41 am
Charles,
Yes, that is my day job address and will work fine. Thanks again.
Post
by MSeriesRebuild » Sat Dec 27, 2008 8:51 am
HingsingM37 wrote: Charles,
The rod is on its way via Priority Mail.
Post
by HingsingM37 » Sun Dec 28, 2008 8:36 am
Thank you sir. Let me know what I owe you for postage
Post
by MSeriesRebuild » Sun Dec 28, 2008 9:18 am
HingsingM37 wrote: Thank you sir. Let me know what I owe you for postage
Merry Christmas & thanks again for the package you sent to me a while back. Charles
Post
by HingsingM37 » Mon Dec 29, 2008 3:13 am
Again thanks
Have a Happy New Year
