Leftovers from my conversion back to 24 V. All of the following are for 12 V system:
Bulbs for marker lights:
(3) bulb, #1156LL, $0.50 for all
http://www.1000bulbs.com/1100-to--1199- ... amps/1568/
Small bulbs for marker lights:
(7) bulb #97/BP2, $1.50 for all
http://www.1000bulbs.com/57-to--98-Indi ... amps/1918/
(4) bulb #67/BA15S, $1 for all
http://www.1000bulbs.com/57-to--98-Indi ... amps/1910/
Aftermarket gauge illumination:
(1) bulb #1593 painted red, free
(2) Hella H4 60/55W bulbs (burners only), $15 for pair
(2) Headlight bulbs, 3 tab connector (standard modern connection - plugs can be found at any auto parts place), $10 for pair
Ignition coil #29650 with bracket (you will have to get your own external resistor) $5
Generator (not originally for M37), Delco-Remy, model 2796? (hard to read data plate) $10
Wheel bearing socket (original), $5
You pay actual shipping.
12 Volt goodies & bearing socket
still available
OK, the noun my wife has been using for my spare parts has changed from a socially acceptable one to one that would make a drunken Sailor blush. All the stuff I have listed is free, you pay for shipping. I may also have some other random brackets & stuff - just ask. Next stop is the trash heap / recycling bucket.
Add to the list a long front bumper (I can't truthfully say "straight" and maintain my dignity
