New technique lifts fingerprints off cleaned guns
nivek
Post by nivek »
Interesting:
kL
http://www.gizmag.com/the-indelible-fingerprint/9519/
Wiping the gun clean has long been considered best practice for villains but may soon become a quaint custom that will ultimately prove fruitless. Researchers have developed a method to ‘visualize fingerprints’ even after the print itself has been removed by measuring the corrosion of the surface by deposits from the fingerprints. The technique can enhance – after firing– a fingerprint that has been deposited on a small caliber metal cartridge case before it is fired. The technique promises the ability to reopen many cases and solve cold cases around the world because the “underlying print never disappears” according to the scientists.
Wiping the gun clean has long been considered best practice for villains but may soon become a quaint custom as researchers have developed a way to ‘visualise fingerprints’ even after the print itself has been removed by measuring the corrosion of the surface by deposits from the fingerprints. The technique can enhance – after firing– a fingerprint that has been deposited on a small calibre metal cartridge case before it is fired. The technique promises the ability to reopen many cases and solve cold cases around the world because the “underlying print never disappears” according to the scientists.
The Forensic Research Centre at the University of Leicester (UK) develops new ways of taking evidence from a crime scene. Already world-leading in such areas as using X-Rays or electrically charging metal surfaces for fingerprint enhancement , they have now developed an entirely new way of detecting fingerprints – great fodder for Crime Scene Investigation fans … and one that could realistically result in thousands of cold cases being reopened around the world.
Forensic scientists at the University of Leicester, working with Northamptonshire Police, have announced a major breakthrough in crime detection which could lead to hundreds of cold cases being reopened.
Dr John Bond, Honorary Fellow at the University of Leicester and Scientific Support Manager at Northamptonshire Police said: “For the first time we can get prints from people who handled a cartridge before it was fired.”
"Wiping it down, washing it in hot soapy water makes no difference - and the heat of the shot helps the process we use.
“The procedure works by applying an electric charge to a metal - say a gun or bullet - which has been coated in a fine conducting powder, similar to that used in photocopiers.
“Even if the fingerprint has been washed off, it leaves a slight corrosion on the metal and this attracts the powder when the charge is applied, so showing up a residual fingerprint.
“The technique works on everything from bullet casings to machine guns. Even if heat vaporises normal clues, police will be able to prove who handled a particular gun.”
Dr. Bond’s initial findings, which prompted the joint study, have been announced in a paper in the American Journal of Forensic Science.
Professor Rob Hillman of the Department of Chemistry added: “It is very satisfying to see excellent fundamental science being applied to a practical problem. We are delighted to have the opportunity to collaborate with Dr. Bond and his colleagues and we look forward to some very exciting chemistry and its application to forensic science.”
As a result of the research, cases dating back decades could be reopened because the underlying print never disappears, say the scientists. The technique also works in cases where prints may be left on other metals.
Dr Bond added: "It's certainly possible hundreds of cold cases could be reopened because with this method the only way to avoid a fingerprint being detected is through abrasive cleaning as that takes a layer off the metal.
Dr Emma Palmer, Director of the Forensic Research Centre said: “This collaboration between the University of Leicester and Northamptonshire Police is an excellent example of applying research to a practical problem in crime detection.”
Dr Bond and Professor Rob Hillman of the Chemistry Department at the University now intend to take this research forward via a three-year Ph.D. studentship to commence next academic year. The new project will explore further the corrosion of metal by fingerprint residue and investigate how it might be used to detect more crime with forensic science.
'52 M-37 "Rusty Red" parted
Thanks! I'll have to remember that if I ever decide to kill my wife! ;)
anthony manzella
finger prints
Post by anthony manzella »
Hay liffer come down my way old Drew peterson can help you out if you need some pointers on the wife thing seems no one has found the last one ! :lol: 8) :wink:
Hit Duh Ground Runnin
Monkey Man
Site Admin
Site Admin
Post by Monkey Man »
Don't get too excited about advice for Lifer, it's your missus you'll need to talk to as she is most likely to knock him off if he brings another M37 home.
Isn't that right Chuck??!! :lol:
Take Care
Best Regards - MM :-)
Trained Monkey on Guard
dodgem37@netspace.net.au
anthony manzella
no finger prints
Hay Monkey Man ! A'nt had no missus over 20 years thank the almighty other wise I could not afford to pay attention much else get $$$$ for parts :lol: :wink: 8)
Monkey Man nailed it with the first shot! LOL We're getting ready to move to the Georgia/South Carolina area, and she has already "suggested" that I "need to get rid of it" so that there'd be one thing less to move. There are just the two of us, since the kids are grown and on their own, but do you think she has any intention of parting with the furnishings for the other three bedrooms? Not on your life! (And, collectively, they probably weigh as much as the M37!)
anthony manzella
FINGER PRINTS
Funny how life goes ! a man ca'nt wait to get out of things after 9 months then is born, then spends alot of time trying to get in, and then spends the rest of his life wishing he never did ! :wink: :lol: 8)
Tom @ Snake River
Post by Tom @ Snake River »
I told my wife that she never has to worry about me committing suicide.
Because when I go, I'm taking her with me. 8)
www.snakeriver4x4.com
G-7117 Chevy
VROD02
Post by VROD02 »
Good thing I bought a sand blaster for the 37 or 45! :shock:
