This is correct!!! I have a NOS section and it is pretty thick and cardboard like. After seeing the differences in Bizal's replacements I might just hold out a bit longer to find the other piece I need to complete or I will cut my own heavy cardboard and glue some thick poster board over the top. I would think by doing that, it would get a bit more accurate.w30bob wrote:Hi Guys,
Here are some pics of the firewall insulation padding in my AF M37. The padding looks to be made of three layers of paper hardboard followed by what looks like layers of corrugated cardboard. I picked up the firewall insulation set from John at Midwest last year.........opened the box....and wasn't impressed...........looks like posterboard I can get at Micheal's craft supply for a buck a sheet. I put it in the corner and will deal with it later down the road, as I'm no where close to that phase of the project. I figure worst case I can use them as patterns if I ever find the correct padding material.![]()
DSC05457 by w30bob, on Flickr
DSC05458 by w30bob, on Flickr
Refit.....question about your data plate.......did you copy that info from your originals? Reason I ask is you stamped in Air Force for the Responsible Agency for all 4 categories. The data plate on my AF truck is stamped ORD DEPT in all those places. I've never seen a data plate that was originally stamped AIR FORCE........so I'm just wondering.
. by w30bob, on Flickr
Next time I see my piece, I will get a pic of it for reference.
