farm truck rustoration
52PLOWERWAGON
Re: its rebuild time
Post by 52PLOWERWAGON »
RMS,
head is stock 6.7 to 1
look at my thread in technical group
called anyone got a vpw high performance camshaft
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
i drove it for a couple hours
its got a ticking noise that gets louder every time we start it
and its losing oil pressure
pulled engine and were lookin for a problem
would a front motor mount bolt on the frame loose make a ticking noise ?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Hi Travis,
I don't think a loose engine mount bolt would make a ticking noise but you never know.
52PLOWERWAGON wrote:engine is almost back together (all except manifolds)
carb is rebuilt
and it turns out my crank was re ground and my old berrings were tighter than the nos ones I ordered
so I reused the old ones
I will sell my nos rod and main bearings (pm me if interested) :)
truck will be back together soon
I think I know why you are losing oil pressure.
Let us know what you find.
52PLOWERWAGON
its not rods valves or timing chain
what about a loose generator one of the bolts rattled loose on that
and my crank shaft pulley is bent
would any of these issues cause a ticking noise
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Post by isaac_alaska »
a bent crankshaft pulley could certainly cause what might be described as a ticking sound, as the belt slaps into the bent spot of the pulley, but wouldn't explain your loss of oil pressure. also wouldn't expect it to get louder as time progresses.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
RMS
Post by RMS »
by using a long screwdriver as a stethoscope the area were the tick is emanating from can be zeroed in.
stock pump ticks, valves tick, too long of a bolt can tick, the seals on the bell housing covers can tick....
are you running a mechanical oil pressure gauge ? .........deletes possible electrical gremlins
52PLOWERWAGON
I'm hoping its the sending unit
when I first bought the truck it had no oil pressure at the gauge until we beat on the sending unit
mechanical gauge Is on long list of needed upgrades
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
pressure relief valve was stuck
engine is back in
whats left on my list
starter
exhaust
wiring and lights
bleed and adjust brakes
fuel lines and filter
then it will be "DONE"
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
glad you got it figured out and fixed, hopefully before it did any damage. i'll definitely be referring to the forum here when i rebuild my spare engine, as soon as i ship it down here. but before shipping i'll measure it and see how far everything has already been ground and bored to make sure it's even worth shipping
Isaac
Fairbanks, AK
Photo Gallery
52PLOWERWAGON
I ordered a nos starter and a used fanshroud from vpw
cant wait to get them and take the old M for a spin 8) 8) :D
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
exhaust is done
now my engine exhales through a 3 inch THRUSH muffler and a four inch stack
electric fuel pump installed
starter is installed finally it only took vpw 3 starters to get me a good one :shock: :shock: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
starter 1 broken arm :shock: :roll: :cry:
starter 2 starter drive frozen to armature shaft :x and jens buttler said that someone in his warehouse was gonna be wearing 3 shoes :shock: :lol:
starter 3 good
next upgrade is petronix and a new distributer lead because now I have no spark
whats left
lights and wiring
get spark
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Travis,
Definitely looking forward to seeing pictures of your project when we see you in IOLA.
52PLOWERWAGON
T. Highway wrote:Hi Travis,
carb is rebuilt
because of my stupid electrical sending unit
now that cant lie to me any more because I have a mechanical gauge now
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
tailgate is mounted now :)
other day I hooked up to my uncles m715 and we pulled off
I dug 4 holes in the ground and neither truck moved 8)
next I'm hooking up with a 2016 ram 2500 HD 6.7 liter Cummins that has 480 hp :mrgreen:
In soft sand
any guesses on who wins :)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Not sure if you saw it, but i pulled a house across sand with my truck. i'm guessing after he gets stuck you'll have to go pull him out haha.
Isaac
Fairbanks, AK
Photo Gallery
