Low compression
Monkey Man
Site Admin
Site Admin
Re: Low compression
Post by Monkey Man »
Can't wait to see the finished result...
MM :D
Trained Monkey on Guard
dodgem37@netspace.net.au
52 M-42
Re: Low compression
Post by 52 M-42 »
The offer is still open if you want to look at a restored truck, Jim. :D
52 M-42
jim lee
Re: Low compression
Post by jim lee »
Here's a current pic. We finally power washed the engine to get the major lumps off.
-jim lee
Re: Low compression
Short sleeves? :shock: It's 6 below zero here.
Keep up the good work.
Re: Low compression
12 or 13 here tonight....
Re: Low compression
What's the matter with you guys.....it's a STEAM pressure washer......he's probably nice and toasty warm! :mrgreen:
It's was 16 F when I got up this morning.....up to about 24 F now!!
Stay warm folks!!
52 M-42
Re: Low compression
Post by 52 M-42 »
I'll have you know it gets truly frigid out here in western Washington! It gets all the way down into the low +40's to high +30's at night! In the day time it might only make it up to the mid +50's at most! It's cold I tell ya'! Serious, serious cold! You should listen to people out here whine about the terrible "arctic" cold they have to suffer. :D :roll:
That poor boy is just too young and innocent to know how cold he is. We often had to tell our children; "Go put a coat on, your mother's cold!" :wink:
52 M-42
DAP
Re: Low compression
Post by DAP »
Morning low today here in Nawth Care-O-Lina was 21 and high was 48. It seems bitter cold but that was because two day's ago it almost got to 70. However if it gets much colder I will have to wrap my M37 tires in barb wire just so I can get traction on the cold cold roads.
I actually like NC weather. Around here they say, if you don't like the weather wait a day or two and it will change. Tuesday I had to plug the block heater in on my M37 Hercules diesel to get the block temp warm enough to get it to start. I don't know how they do it in Alaska where I was born. I like working up sweat in January in a T-shirt hauling firewood with my M37 and M101 trailer. Sure beats the cold dampness of NJ where I grew up as a kid.
1962 M37B1
1962 M116A1 Generator trailer
1964 M101A1 3/4 ton trailer
jim lee
Re: Low compression
Post by jim lee »
We were able to get a little time this sunday for stripping the engine down some. We were able to get the gear box off as expected, but the bell housing is not coming off. It looks like all the bolts are removed, the bottom and front covers are removed. The bell housing comes out about 1/8" or so and stops. Is there a trick to this I'm missing? Is there something inside there that I need to remove before it releases?
Any help would be greatly appreciated!
And, on another note, Julie (the wife) kept taking the wrenches from the kids and volunteering to pull stuff apart. I was like, "Julie really you don't have to.. " And she looked up,
"No really I like doing this, its fun!"
I just kinda' looked at her somewhat stunned. "Really?"
-jim lee
vtdeucedriver
Re: Low compression
Post by vtdeucedriver »
-jim lee
You know you dont have to brag.
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
jim lee
Re: Low compression
Post by jim lee »
Wasn't bragging, was shocked. Well at least I didn't mean to..
No hints on removing the bell housing? Anyone?
The military manuals don't seem to say anything about it.
-jim lee
j mccormick
Re: Low compression
Post by j mccormick »
From the looks of no.3 cylinder I would say its definitely going past the rings. Whenever there's that much ash on the piston and clean around the outer portion of the piston your rings are either worn or stuck, most likely in your case, stuck.
j mccormick
Re: Low compression
The bell housing will only move back a short distance until it contacts the flywheel. There are 2 bolts near the bottom of the block on both sides and 2 at the top of the housing. In between the 2 bottom bolts on each side is a dowel pin that correctly aligns the housing on the block. My guess is the dowel pins need to be driven back slightly so they disengage from the block. Then the housing will lift straight up off the flywheel.
Re: Low compression
Jim,
Thanks for posting the pictures. Nice to see the whole family helping out. Enjoy your project! :)
jim lee
Re: Low compression
Post by jim lee »
Kids had to stay home do homework, but at least we had a little time to put in on the engine this sunday. Almost ready to bolt onto the engine stand.
Lets hope this image link works..
Pulling bell housing. Turns out you have to drop everything, clutch & flywheel out the bottom first. Ey yiyi!
And.. it turns out theres a guy in our area that specializes in Flat head engine machine work. Woo hoo!
-jim lee
