I got them to got up and down relativly easily. They have a very crude roller system on the bottom. Needs lots of grease. I saw your limiters. My originals were so beat up and the doors were really badly damaged so I decided to weld them shut and install these. Straps are a wee bit short, the doors don't quite open to 90 degrees but good enough for now. the seal on the windshield (for the door glass) has one end square and the other end tapered. Am I correct in saying the tapered end goes up?m-37Bruce wrote:In the TM, it shows how to adjust the windows, rubber or wooden mallet a 2" X 4" as I recall?
This is how my door arm checks turned out for me.
http://www.g741.org/photogallery/main.php?g2_itemId=562
Building a retro M37
- retiredguy
- SGT
Re: Building a retro M37
Are you speaking of the gasket that attaches to the windscreen bottom?retiredguy wrote:I got them to got up and down relativly easily. They have a very crude roller system on the bottom. Needs lots of grease. I saw your limiters. My originals were so beat up and the doors were really badly damaged so I decided to weld them shut and install these. Straps are a wee bit short, the doors don't quite open to 90 degrees but good enough for now. the seal on the windshield (for the door glass) has one end square and the other end tapered. Am I correct in saying the tapered end goes up?m-37Bruce wrote:In the TM, it shows how to adjust the windows, rubber or wooden mallet a 2" X 4" as I recall?
- retiredguy
- SGT
I was working on the seal that goes up and down at the very end of the windscreen. The one that the door window hits when door is closed.
OK, I think the longer lip side goes on the inside, we are talking about the felted rubber, right?
- retiredguy
- SGT
Yes that is the one. I kinda figured that out but what i didn't is the ends. One one is squared off and the other end is cut at an angle
There is a left and a right. the mitered enis the top and there is a horizontal one on the top frame which will also be mitered making the corner.
Tim
Tim
Tim has it right, miter the top corners, bottoms flat in the channel.powerwagontim wrote:There is a left and a right. the mitered enis the top and there is a horizontal one on the top frame which will also be mitered making the corner.
Tim
- retiredguy
- SGT
Thanks guys. My old ones were non existant so it was hard to tell.
Did you use the wiring harness that was already on the truck, or aftermarket (i.e. Painless)? Combo of both? Im trying to locate a harness that will work in conjunction with the existing platform. Thinking a 73-87 chevy truck will probably do the job.
- retiredguy
- SGT
I used no pre-made wirinf harness. I hand wired it all from scratch out of my head and used color coded wires and wrote down what wire went where. The firewall connectors had numbered pins so I documented each pin number and what color it was and what it serviced.
- retiredguy
- SGT
Here is the finished LH inner fender cover. It is to cover the area that the M37 inner fender did not cover (area between frame and inner fender) Doing the RH side now. Question next is : I there a seal between the cab roof and the mating surface? (rear of the cab tub and the top of the windscreen). Or do I put a generic one in?
TM 9-2855-7 Hard-Top Closure Kitretiredguy wrote:Question next is : I there a seal between the cab roof and the mating surface? (rear of the cab tub and the top of the windscreen). Or do I put a generic one in?
Page #6 Says to apply a quantity of sealant along the top of the windshield frame and side supports. Nothing mentioned about a gasket in the TM.
- retiredguy
- SGT
I'm kinda reluctant to use a sealant because if you want to remove the top for a week or two in the summer it may be glued down too hard. I thought I might try that thin foam gasket material but in the case of the top of the windshield the way you have to install the top it may destroy the gasket anyway. Looks like you have to hook the top into the top of the windshield frame and then slide it rearward into place . that sliding would push the gasket out. I guess I'll have to use trial and error method.
You may want to find a local RV dealer, they have a closed cell foam gasket that has a thin plastic skin on one side that may do exactly what you are looking for.
Is that a rubber sheet or plastic? How is it attached?retiredguy wrote:Here is the finished LH inner fender cover. It is to cover the area that the M37 inner fender did not cover (area between frame and inner fender) Doing the RH side now. Question next is : I there a seal between the cab roof and the mating surface? (rear of the cab tub and the top of the windscreen). Or do I put a generic one in?
