MECO spark plugs, DON'T BUY THEM
Murf
Re: MECO spark plugs, DON'T BUY THEM
Post by Murf »
How about someone post the Champion Spark Plug
There are at least three Champion plug numbers that will work in the OEM military shielded system (the supercede part number is in parens):
- 514 (XEJ-8) - cold / medium temp range
- 588 (XMJ14) - cold temp range
- 573 (XMJ20) - standard temp range (?)
There might be other Champion plugs, along with similar plugs from Autolite.
The 573 or XMJ20 are the ones that have worked best for us.
Murf
Post by Murf »
Thanks to both of you!
deltaracer
Post by deltaracer »
States heat range for Champion 573 (XMJ20) is---20
1963 M151
1964 M416
1963 M37B1
