A large majority of items we build are done in house, these are easy to whip out in just a few minutes as needed. Most people never order things like this because they are so simple to fab up.Chris P wrote:Thanks for the replies.
Charles, in the past I've bought things from you because you've had them fabricated in quantity. But I guess that's for things you contract out, whereas something like this you can just make one yourself whenever you need one.
Leaky Fuel pump diaphragm
Re: Leaky Fuel pump diaphragm
thanks for the advice Charles, i have a 24V facet on the way, 4-6psi. do i probably need a pressure regulator with that? i saw your spec says 4psi max. i'm also going to go ahead and replace the fuel pump on my civi while i'm at it, be a shame to get it all back together and then have the fuel pump fail and take the engine out with it.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
I would use a regulator with a 6 PSI pump.isaac_alaska wrote:thanks for the advice Charles, i have a 24V facet on the way, 4-6psi. do i probably need a pressure regulator with that? i saw your spec says 4psi max. i'm also going to go ahead and replace the fuel pump on my civi while i'm at it, be a shame to get it all back together and then have the fuel pump fail and take the engine out with it.
Can you run an electric pump for the fuel bypassing the machanical pump, and keep the mechanical pump on the engine for the vacuum side? Worst case here you loose the diaphram and wipers?
Not at all familiar with these pumps. Just reading here and wondering.
Yes you can do that, BUT don't expect great strides in relation to wiper boost. Vacuum wipers are poor at best, and the amount of boost that pump can furnish is very minimal, even if it's in top shape. Not likely that you will actually tell any difference in wiper action with or without the boost to be honest.oros35 wrote:Can you run an electric pump for the fuel bypassing the machanical pump, and keep the mechanical pump on the engine for the vacuum side? Worst case here you loose the diaphram and wipers?
where are the wipers normally routed to? manifold vacuum? i still have a lot to learn, that's why i love this site! thanks for the help
Isaac
Fairbanks, AK
Photo Gallery
Fairbanks, AK
Photo Gallery
The stock vacuum wipers are plumbed directly to the "outlet" side of the vacuum circuit of the fuel pump. The "inlet" side of the fuel pump vacuum circuit is routed to the intake manifold.
