No oil pressure!
vtdeucedriver
Re: No oil pressure!
Post by vtdeucedriver »
m37jarhead wrote:Charles:
I used Permatex Aviation "Form-A-Gasket" sealant liquid on the horse shoe shaped tube. Also torqued these fittings
and nuts very stout.
JB
Tight Seal???
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
m37jarhead
Post by m37jarhead »
Both tubes were removed and re-sealed with Permatex High Temp Thread Sealer.
Applied resonable torque. Should be fine.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Glad to hear you resolved your issue. Congrats :)
m37jarhead
Thanks David, after investing a good bit of money at the machine shop and tons more money on new internal parts,
I was glad to hear the beast roar with oil pressure. Obviously I was worried about frying the bearings. I now
believe the loose oil pickup tube was sucking up "some" oil and did not allow the the bearings to run dry. Removal
of the bearing caps, rods and mains, showed oil dripping off the inside of the caps and bearing surfaces.
Just goes to show you that the smallest error, not tightening the tube correctly, can turn yur day into an
expensive learning opportunity.
Jerry (JB)
Past Pres
Member: MVPA #26600
Member: NRA
That it can; BUT that is a lot cheaper than galled bearings due to oil starvation.
