defroster vent
DaveO
Post by DaveO »
Can anyone comment on the effectiveness of these defrost features?
Hiya,
I'm running the M151 heater into a M37 defrosting duct. It works pretty well, and air distribution is adequate. The only time it struggles is in a heavy, wet snow. The combination of a wiper system that wasn't designed for these conditions, and an air temp of 180 max, means that my windshield tends to load up.
It sure beats the winter that I didn't have anything but a chamois!
Dave
Dave Ostlund
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
mike_l
Defroster Duct
Post by mike_l »
I think the duct works pretty good though I only used it twice. It was only about 10-20 degrees for about 45 minutes each time. Not much of a test but it worked OK. Had more of a problem with the door windows fogging up as I recall.
I found a copy of the defroster dimensions from an old post. Try this: http://www.g741.org/photogallery/main.p ... ewsIndex=1
Mike
Marion, IN
1954 M37 W/OW
1953 M101
Indiana MVPA
TOM R
Post by TOM R »
I did notice installing mine that you need to start the bolts on the drivers side then use an alignment pin to pry the pass side holes into alignment, i used an nos defroster not bent, anyone else have to do this?
also how did you adapt the 151 hose to the m37 duct or did you just leave it in the duct loose?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
mike_l
Post by mike_l »
Mine mated up to the bolt holes with no problems but it was used and may already have be "aligned" at some point.
Mike
Marion, IN
1954 M37 W/OW
1953 M101
Indiana MVPA
