Paint color for a 1953 M-37
- Tim Powell
- MSGT
Re: Paint color for a 1953 M-37
"they would mix the two paints together until it produced an OD green (i.e.24087)." Explain this number if you would??? 24087?
24087 refers to a particular color mixed in accordance with a set of specs known as the Federal Standard (FS). It is a semi-gloss darkish OD that was used throughout the Vietnam War on vehicles. IIRC when the FS specs changed in 1995, 24087 was re-formulated into a lighter, yellowish version. The current spec for 24084 is very close to what the Vietnam War era 24087 used to be.
- Tim Powell
- MSGT
Thanks WarrenD. What would be the original O/D for 1952?
See Wes' post on page 1 of this thread, he goes thru the history.
- Tim Powell
- MSGT
Will-do!
They would mix the green and yellow together to get a color close to the late 1960's standard color that was explained above. But in talking to these guys the color was more of a dark green than a brown green, but 24087 is a camilion color in that in certain light it looks more brown green and in other light it looks more dark green. So it worked for them.Tim Powell wrote:"they would mix the two paints together until it produced an OD green (i.e.24087)." Explain this number if you would??? 24087?
