I plan on it. As a aircraft mechanic, I've messed with the heaters before.cuz wrote:The TB listed was for the Hot water Heater Kit. Your Gas Fired Heater Kit has it's own TB and is also a common unit. It pays to do a pressure decay check on those gas fired heaters periodically. Also you should use a Carbon Monoxide warning card or detector in the cab.
m37 fender heater instructions/inventory
Re: m37 fender heater instructions/inventory
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
I am also an aircraft mech and IA and own my FBO here in WI. Have you access to a test set?
Yea I can borrow one. I did a couple of yrs at a FBO working GA. We maintained a couple of Barrons and 2 Seneca's and since I got pretty good at NOT blowing the bulb, I was usually the one that did it. I dont know whos doing it now that I no longer work there.cuz wrote:I am also an aircraft mech and IA and own my FBO here in WI. Have you access to a test set?
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
