Electric fuel pumps
cuz
Re: Electric fuel pumps
Post by cuz »
No one is arguing the placement of non-high lift pumps. They belong back there within 12" of the tank.
The high lift pumps can be mounted up front on the fender that is away from the exhaust manifold and will perform just fine up there for many years.
hbb
Post by hbb »
Cuz
I must be looking at a different pump! which pump is the high lift pump your talking about? All of the pumps from Facet are pusher pumps not suck pumps like the original vacuum pumps that were installed on the engine.
I really am interested in a high lift eclectic pump and it's specifications on how much draw they have and how much head pressure they will build after the max draw is attained so I can expect to include or exclude pressure regulators in the end run.
Thanks Looking forward to that info.
hb
cuz
Post by cuz »
I already posted that on page one of this thread. Just click on the two links for the specs on these suck pumps.
As a general rule the above comments are correct but for those that wish not to locate their pumps under the truck and at the aft end there are electric pumps out there that are specifically designed for high lift from 12 inches to 10 feet.
Facet® Posi-Flo® Fuel Pumps
This is an outstanding, lightweight universal electronic fuel pump with state-of-the-art design that can be used in all carburetor-equipped vehicles and also as a diesel lift pump. In many applications, the advanced technology engineered into the Facet POSI-FLO fuel pump allows for a convenient interchange with the cube fuel pump. In addition it runs quieter, 65DB, versus the noise levels exhibited by earlier competitive solid state technologies. It is rated for 6000 hours of performance. The Facet Posi-Flo Fuel Pump's self-priming capabilities provide up to 12 inches of fuel lift and no extended cranking is necessary to restart the engine if "out-of-fuel" conditions occur.
http://www.facet-purolator.com/index.ph ... &Itemid=35
Click here for more information
Click here for pdf
Facet® Dura-Lift® Fuel Pumps
When you need a tough, hard working fuel pump for diesel transfer applications such as truck refrigeration units, generator sets or gas fuel supply systems then the Facet Dura-Lift is the answer. With a minimum lift of 10 feet, these fuel pumps provide outputs up to 125 liters per hour, 11.5 psi .76 bar. In thousands of proven on-the-job applications, these pumps have earned the reputation to wear the name – Facet.
http://www.facet-purolator.com/index.ph ... &Itemid=37
Click here for pdf
Hi guys,
I installed the Posi-Flow fuel pump this past weekend and a short test run afterward revealed no difficulties: carb getting plenty of fuel but not too much. I had some concerns about the pump defeating the carb float needle valve but that hasn't been an issue.
