so, I promised Id spill the beans, and, I actually put this (mostly) together a LOT faster than I thought I would. As you all can tell from the model, that is one hellaciously complicated hunk of modern art/intake plenum. As such, I know anything I try to weld up will look terrible
so.....
I'm going to cast them.
First step is to make a positive mold. After a bit of debating, I decided to do a wood mold, as I have a decent array of wood tools (another one of my hobbies) and A wood mold is infinately reusable, so long as I am gentle with it. This way, if I dont get the gating or risers right, I simple cast another plaster mold around my wooden model and keep pouring till I get it right.
So, I started out by ripping a 2X4 dow to 14" long chunks squared off at 1.5"X2.75".
I glued 6 of these together, then another 6 to form two 14"X6"X2.75" blocks. The seam in between them is not glued, and that is intentional, you'll see why in a bit.
I then traced the respective patterns on each end using dimensions from teh computer model. Unfortunately, I dont have a printer, otehrwise I would have just printed each end view, cut it out, and glued it on. For Throttle Bodies, I'm going to use a pair of ford 65mm Mustang 4.6L bodies I got at my local you pull it yard for $10 each. 65mm is 2.55 inches, perforct for the 2.5: discharge out of the Holset turbos.
TB end:
Opposite end:
And, in this picture, you can see the reason for the seam in the middle:
Next step was to trace and cut the taper on the Lehman Chamber:
Then, deck the sides:
then, go wild with the table saw, and remove as much material as possible:
then, after making all these:
And some sanding (I got smart and put an 80 grit flapper wheel on my 4 1/2" grinder... made on heck of a mess, bet it cleaned it up fast, especially those pesky knots!)
you get this:
I like the candy stripe of the pine mixed with the red doug fir. I didnt do it on pupose, I just used what wood I had lying around
Then, ripped some 1/8" thick end plates oout of plywood on the tablesaw, and cut the profile on the scroll saw:
And, I'm going to make a slight tweak to the original design. In the original design, I had a slot taken out between the runners. Im going to try to avoid doing that, and, instead, make a steel backing plate that will gasket joint to the face of the plenum. Then, steel runners down to teh heads. This is for two reasons: 1. servicability. I can disassemble the entire unit then. And 2. vibration. Long curvy cast aluminum runners would be a pain to make, and would most likely crack from theweight of such a large plenum hanging off the end.
to do that, I of course need a gasket surface, and that is what this is for:
I'll drill and tap that for bolts, and bolt the steel end plate to it. That 3/4" thick plywood, which will give me a good thick gasket surface I can machine flat and then drill and tap.
