Nate, buddy of mine. Runs a VW repair shop. Working on removing frozen broken bolt from the intake manifold.
Heat and other tricks did't do it. The remainder of the bolt sheared off at the face of the casting. Bother! Now its time to drill it out and re-tap the threads.
Nate loaned me an ultrasonic cleaner. Pretty handy for things like throttle linkages.
This stumped me for a bit. My first thought was "Yet another needlessly overcomplicated part." Turns out the gold ring is an adapter so you can run a modern thermostat in the truck.
Its been over 30 years since I did this kind of stuff. Had to get tooled up again. This is a fuel line patch I made up to replace the nasty fuel line patch from the PO.
My little patch installed. I think this is where the primer pump was plumbed in originally. When we got the truck there was foot long pipes coming off these and a big 'ol rubber loop tying them together.
Why is everything so hard? Put the thermostat on and the bolts bottomed out. Pulled it all apart again and re-tapped the holes.
A fine example of the state of the original fasteners.
Some of the better fasteners. These lived drenched in dripping engine oil so they survived the ravages of time better.
I've finally given up on the old hardware. I've started taking the screws, nuts & bolts to the store, then buy a sack of each. Slowly the inventory is building up. But things sure do fit together better now!
Finally! The thermostat thing is all installed.
Housing!
I've been thinking about why this is taking so bloody long. Much of the time is spent tooling up and getting parts. I'll spend a week waiting for some part or tool then be able to move forward one little step. Then its back to ordering & purchasing for the next step. On top of that, every part seems to want some special attention. Clearing threads, removing broken studs, flattening surfaces. It seems closer to building an engine by hand than slapping together something like a Small Block Chevy.
Anyway, that's where we are now. I ordered the manifold fasteners from MSeriesRebuild. Of the four I had three and one of my brass washers was cracked in half.
Also just ordered another bunch of stuff from Midwest Military.
Fuel filters, Before or after the fuel pump and why? I tend to think before, but lets see what you all come up with.
-jim lee
