Moderators: Cal_Gary , T. Highway , Monkey Man , robi
sturmtyger380
Posts: 580 Joined: Sun Oct 21, 2007 5:13 pm
Post
by sturmtyger380 » Tue Nov 15, 2016 4:52 pm
I keep digging into the M37 I have down here in South Carolina. I have all the floor covers off and noticed the front prop shaft is really gnarly.
Anyone have a good front prop shaft they would like to part with?
Alan
isaac_alaska
Posts: 557 Joined: Tue Jul 07, 2015 10:44 pm
Post
by isaac_alaska » Tue Nov 15, 2016 5:14 pm
most driveshaft shops can probably cut the bad section out and rebuild it for you for fairly cheap. i definitely wouldn't run it like that! it'll twist off in a second haha
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
BILL L
Posts: 197 Joined: Sat Oct 20, 2007 4:05 am
Post
by BILL L » Wed Nov 16, 2016 5:25 am
Email me I might be able to help you.
Autodoc51@aol.com Ocala,FL
Drew M.
Posts: 111 Joined: Wed Apr 02, 2008 7:49 pm
Post
by Drew M. » Wed Nov 16, 2016 12:22 pm
To cut down a driveshaft at a shop is inexpensive (~$75). However, replacing the pipe or adding length is $$$$$! IMHO: Get a used driveshaft.
Oddball-CmK
Posts: 105 Joined: Sun Feb 20, 2011 7:12 pm
Post
by Oddball-CmK » Thu Nov 17, 2016 5:53 pm
I believe I have one, the first one pictured without the yoke. If you're interested, $65 plus shipping.
Regards,
Cordell
sturmtyger380
Post
by sturmtyger380 » Fri Nov 18, 2016 6:11 am
I have a couple of leads at the moment but I will get back to you.
xm708
Posts: 495 Joined: Sat Oct 20, 2007 6:24 am
Post
by xm708 » Fri Nov 18, 2016 2:56 pm
If everybody falls through I have at least a dozen !!
