legacy Camber shims
RMS
legacy Camber shims
Post by RMS »
what are your thoughts on the legacy .0009 negative Camber shims for the Chrysler 9 3/4 axle ?Image
Re: legacy Camber shims
What's the point of them?
Interesting idea, they may work well w/ radials. If nothing else they would stand up the fronts a bit and eliminate some of the outside shoulder wear I'm seeing on my new superlugs.
Yes, very interesting.
RMS, where did you find those shims?
RMS
Post by RMS »
the shims showed up on my fb news feed they are made by http://www.legacypowerwagon.com/
switching from positive camber to negative is apparently "The secret to great driving early dodge trucks. 65mph one hand on the wheel." negative camber would also decrease under steer
I wouldn't bother with my truck. There doesn't seem much need on a vehicle that can only be coaxed to 45 MPH. And, since I don't have tire wear issues with mine and the stock tires, they wouldn't help. However, a 4.89 geared truck with a v8 and big wide tires, that could help.
RMS wrote:the shims showed up on my fb news feed they are made by http://www.legacypowerwagon.com/
Thanks, Robyn.
These shims might make sense for trucks that are driven primarily on hard surfaces, at higher than original design speeds, and/or equipped with a power steering conversion? I'm not sure I'd want it on a stock M37.
