Douglas wiring
Dutch
Douglas wiring
Post by Dutch »
Does anyone know where you can order the barrel terminals and other parts from?Or what their correct name is i say barrel terminal but I don't know if that correct. If you go to a company like Mouser Electronics they have terminal but there are like 22,000 different types and I don't know where to start. I am talking like a box of the terminals. I know there are military parts suppliers that will sell you 1 connection kit with the shells and terminals and everything for like 5$ but I feel like there has to be a supplier somewhere where I can go and get a box of 100 terminal if I want them or a box of 50 of the bushings or grommets and not have to buy everything. Any help would be much appreciated, thanks.
(Moved to the Tech section)T. Highway
isaac_alaska
Re: Douglas wiring
Post by isaac_alaska »
Ebay "vintage Douglas connector" and scroll till you find what you want. I've seen them for 14 and 16awg, male or female, packs of 1 or 10, or a full set of 1 each to do a single connection male and female. I just ordered a female connector to tie into an old electric fuel pump I discovrred bolted into my truck but never hooked up.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
w30bob
Re: Douglas wiring
Post by w30bob »
Hi Dutch,
Isaac is right, they're called Douglas Connectors..........male and female. Cheapest I've found them is from Erik's if you need 10 or more;
http://search.store.yahoo.net/yhst-5952 ... lus.com%2F
or if you only need a couple then check Saturn Supply.
Cav Trooper
Re: Douglas wiring
Post by Cav Trooper »
You can also check with Star Electric Ordnance, He covers all M series electrical parts. Kevin Emdee email at Kevin.Emdee@comcast.net or phone 270-877-0813
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
