anybody got a vpw high preformance camshaft
looking for reviews before I order
I don't know anything about cams some one please educate me so I at least have an idea what I'm talking about.
Re: anybody got a vpw high preformance camshaft
Cams are magical mystery math. What are you trying to do? Most of the times, for basically stock engines, they are wasted expense. You can move torque curve up or down the rpm scale but with our flat sixes, the curve peaks just off idle and is pretty flat to the top of the rpm range. Without adding bigger or more carbs, bumping compression and balancing for higher rpm operation, the stock ones should be fine.
I was under the impression that that the vpw cam had more lift (410)designed to work better with today's petrol giving you increases in torque and hp at the same rpm. granted bumming the compression by installing a car head or milling down your stock head is still the best $ to gains.
thanks gonna order overhaul parts today
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
I have never used the VPW cam as I have a cam grinder here in WA. Delta Camshafts in Tacoma . They will grind it how ever you want. or just tell them what your doing and they will suggest one. big improvement over stock. I also recommend shaving .060 or more off stock head. The stock cam is designed for 70 octane fuel. so 89 octane is like race fuel for stock cam;. there is tons of room for improvement. a new cam and shaved head really makes the truck drive great!
I ordered one
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Who did you order from and what did you get?
vpw it is custom ground for more duration
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
I cant wait to try it
it came with a spec sheet should I post pics
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
mine was ground by ISKY RACING CAMSKaegi wrote:I have never used the VPW cam as I have a cam grinder here in WA. Delta Camshafts in Tacoma . They will grind it how ever you want. or just tell them what your doing and they will suggest one. big improvement over stock. I also recommend shaving .060 or more off stock head. The stock cam is designed for 70 octane fuel. so 89 octane is like race fuel for stock cam;. there is tons of room for improvement. a new cam and shaved head really makes the truck drive great!
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON wrote:I cant wait to try it![]()
yes, we love pics around here.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
it might be a while but they will get up
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Here are the Isky cam specs for the Dodge 230 flathead engine. This is the cam that Vintage Power Wagons is selling. It is a NOS cam that is reground by Iskenderian Racing Cams for them.
- isky cam specs.pdf
- (99.93 KiB) Downloaded 125 times
that cam gives the engine lots more response
and man is it PEPPY!
now my truck sounds like a HARLEY !!!!!!
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
