oil press. sender
hairpin151
oil press. sender
Post by hairpin151 »
Anyone got an extra 0-60lbs sender with the metal (Douglas) connector? I'm thinking thats the culprit as my gauge pegs to 60lbs and stays there and I've tried a different gauge,same thing. Any help is appreciated.Thanks.
hairpin151
Got one from Jay at FLMV,installed and all is well.Thanks
monkeymissile
Post by monkeymissile »
could you post their contact info when you get a chance? I may need one too. Thanks.
1953 Dodge M43
Fail often to succeed sooner
hairpin151
717-252-4489, dont have their web address in front of me.
N1VSM
If you have the chance ...
Post by N1VSM »
hairpin151 wrote:Got one from Jay at FLMV,installed and all is well.Thanks
I've been trying to track down a problem in my temp gauge. I checked the wire (it is fine - new), swapped out both the gauge and the sensor with ones that tested good.
Could you (or anyone?) tell me what voltages or resistances I should measure when testing cold and hot?
hairpin151
I wish I could help but fraid not.I would defer to the 8030 manual possibly.
m-11
Post by m-11 »
Are you looking for this website? www.flmv.net
