Fuel pump ?
Gerry
Fuel pump ?
Post by Gerry »
What is the correct color to paint the fuel pump? Also what should I use on the threads of the fuel fittings?
Gerry
53 M37
Lifer
Post by Lifer »
Engine accessories were painted black from the factory. The engines were silver. At the first overhaul, everything got repainted. For Army trucks, the starters and generators were left black, but everything else got painted OD. The AF required that the engines be repainted gray after being rebuilt, but the starters and generators remained black. Often, however, when a fuel pump was replaced, it was not painted. Therefore, an unpainted fuel pump would still be "correct" unless you're planning to do a "factory" restoration.
Gerry
Post by Gerry »
Is the black semi-gloss?
I plan on doing things factory when possible, but a lot will be done motorpool.
Gerry
53 M37
Lifer
Post by Lifer »
I can't say for certain, but I'd imagine it would match the black on the generator, starter, air cleaner, oil filler pipe (the cap on that should be red), distributor, etc. Semi-gloss would be my guess, anyway.
knattrass
Post by knattrass »
Tony at T&N left the casting plain aluminum, only painted the screws black.
Image[/img]
Gerry
Post by Gerry »
Just got mine back from Tony. Looks great.
Gerry
53 M37
peter e mark
Post by peter e mark »
p[img][img][/img]Well, i tried to post a picture....no luck yet
1952 M37 W/W
ron
fuel pump
Post by ron »
Knattrass, would you please give me some information on the company [ T & N ] I might need to have my pump rebuilt, thanks Ron
refit1701
Post by refit1701 »
It's "Then and Now".
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
peter e mark
Then And Now ?
1952 M37 W/W
knattrass
Post by knattrass »
The place is Then & Now Automotive, they are in S. Weymouth MA. Phone is 781.335.1579.
Ask for Tony (mgr) or Greg (who does the work).
I sent them a pump that was in the box of "stuff" from the previous owner - looked like it had been dragged down a oily dirt road. I was almost embrassed to send it. You are looking at the photo of it after. The only thing I had to do was swap the 2 top screws because the standoff for the heat shield was in the wrong spot to line up.
peter e mark
Thank You...
1952 M37 W/W
peter e mark
In re-reading this thread, I am again impressed how so many of the participants of this group do in fact restore thier vehcles to " factory" It must be that I am being influenced as I bought a spray painter (!) A big change for a brush it on reenactor man like me where all that matters is to keep the truck running for reenactment battles and parades. Well, with two jobs I don't have the time to restore on factory level but I think I will when my schedule changes, and just to let you all know I sure apprciate the level of quality I see among you all...
1952 M37 W/W
monkeymissile
Post by monkeymissile »
just got a rebuild kit from Tom at Then&Now. With any luck I'll be taking apart and cleaning my pump over the weekend.
What do folks prefer to use as a cleaner/degreaser? I was planning to use Simple Green since it's a bit more earth friendly. Your thoughts?
1953 Dodge M43
Fail often to succeed sooner
Lifer
Post by Lifer »
I just noticed something interesting while reading T.O. 36-1-3, Painting and Marking of USAF Vehicles. Section II, Para 2(b)(11) states that "engines, engine accessories, and components requiring repainting will be painted with full gloss, gray, color number 1610."
That description would seem to include the fuel pump.
I don't know what Army, Navy, or Marine Corps publications apply, but I imagine they offer similar instructions with regard to color.
