Fuel pump ?
Fuel pump ?
What is the correct color to paint the fuel pump? Also what should I use on the threads of the fuel fittings?
Gerry
53 M37
53 M37
Engine accessories were painted black from the factory. The engines were silver. At the first overhaul, everything got repainted. For Army trucks, the starters and generators were left black, but everything else got painted OD. The AF required that the engines be repainted gray after being rebuilt, but the starters and generators remained black. Often, however, when a fuel pump was replaced, it was not painted. Therefore, an unpainted fuel pump would still be "correct" unless you're planning to do a "factory" restoration.
- SSGT
- SSGT
The place is Then & Now Automotive, they are in S. Weymouth MA. Phone is 781.335.1579.
Ask for Tony (mgr) or Greg (who does the work).
I sent them a pump that was in the box of "stuff" from the previous owner - looked like it had been dragged down a oily dirt road. I was almost embrassed to send it. You are looking at the photo of it after. The only thing I had to do was swap the 2 top screws because the standoff for the heat shield was in the wrong spot to line up.
- SSGT
- SSGT
In re-reading this thread, I am again impressed how so many of the participants of this group do in fact restore thier vehcles to " factory" It must be that I am being influenced as I bought a spray painter (!) A big change for a brush it on reenactor man like me where all that matters is to keep the truck running for reenactment battles and parades. Well, with two jobs I don't have the time to restore on factory level but I think I will when my schedule changes, and just to let you all know I sure apprciate the level of quality I see among you all...
1952 M37 W/W
- SSGT
just got a rebuild kit from Tom at Then&Now. With any luck I'll be taking apart and cleaning my pump over the weekend.
What do folks prefer to use as a cleaner/degreaser? I was planning to use Simple Green since it's a bit more earth friendly. Your thoughts?
1953 Dodge M43
Fail often to succeed sooner
I just noticed something interesting while reading T.O. 36-1-3, Painting and Marking of USAF Vehicles. Section II, Para 2(b)(11) states that "engines, engine accessories, and components requiring repainting will be painted with full gloss, gray, color number 1610."
That description would seem to include the fuel pump.
I don't know what Army, Navy, or Marine Corps publications apply, but I imagine they offer similar instructions with regard to color.
