Has anyone found a source for the rubber seal that seats between the frame and the cut out in the back of the cab? L cross section applied with adhesive.
How about a replacement for the U shaped glide that the window slides on? It looks like the government originally used a "fuzzy" that you see on sides of windows from the 50's. Not a durable choice.
I ended up getting a box of 5/16-24 square weldment nuts (McMaster Carr) which are tacked into the cab sheet metal frame to attach the window frame. Only needed to replace a few and have lots left over. Happy to pass along if anybody needs them.
Rick
Metal top sliding rear window
RICK
M 152 CDN
M 56 (V41)
M 152 CDN
M 56 (V41)
