door handle bezels
Gerry
door handle bezels
Post by Gerry »
Is there an easy way to remove the inside handle bezels to sand blast.
Gerry
53 M37
52 M-42
Re: door handle bezels
Post by 52 M-42 »
3 hands help, but 2 bodies gets a little crowded.
You need to compress the smaller, upper ring into the larger, lower ring by raising the lower ring so that you can push out the pin in the door handle; and oh, by the way don't lose that little pin. :wink: A proper size pin punch is the best way (I think it is a 1/8th inch punch).
Then everything should come off. Theoretically, anyway. If nothing is rusted or jammed.
Are you going to media blast the bezels? I think they are aluminum. Maybe use stripper instead? I don't remember if mine were plastic blasted or chemically stripped.
Good Luck with your project!
52 M-42
Gerry
Post by Gerry »
Thanks for the info. maybe I will just lightly sand them.
Gerry
53 M37
rickv100
Post by rickv100 »
The bezels are steel.
Rick
DSC01171 (Small).JPG (100.38 KiB) Viewed 866 times
pic
