Rear Pinion Seal Adapter
Hi, I'm in the process of replacing my rear pinion seal. My work has offered to make an adapter so I can use a rubber seal rather than a leather one. Can someone let me know what the outside diameter of the adapter should be in order to fit inside the rear housing? My caliper arms are not deep enough to go around the shaft to measure it correctly. Please help. Thanks
Re: Rear Pinion Seal Adapter
If you have interest, we offer an adapter with a current production double lip seal installed. Kit comes with a redi-sleeve for the yoke as well.mix4coal wrote:Hi, I'm in the process of replacing my rear pinion seal. My work has offered to make an adapter so I can use a rubber seal rather than a leather one. Can someone let me know what the outside diameter of the adapter should be in order to fit inside the rear housing? My caliper arms are not deep enough to go around the shaft to measure it correctly. Please help. Thanks
