I just purchased an m37 that sat for the last four years. should I try to clean the carb before I try to start her or should I just see what happens?
Carb ?
I pulled the top off of mine and checked to see if there was a bunch of junk in it.
I was able to get it to sorta run, but the carb was in bad need of a rebuild, which I did later.
I'd at least shoot some carb cleaner into every hole I could get it into.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
S-89 Comm box
Re: Carb ?
The smart route to take is to go ahead & attend to the obvious first. You said it had sit for 4 years, the obvious being, rebuild the distributor, rebuild the carb, rebuild the fuel pump (may well keep from dumping gas into the oil pan), clean the fuel tank & replace all filters. Blowing out the lines is also wise. Check out the spark plugs replacing same if the need is obvious, check the cables for continuity. Change the engine oil & filter, be sure the radiator is full & give it a spin hoping worse problems don't become evident.Gerry wrote:I just purchased an m37 that sat for the last four years. should I try to clean the carb before I try to start her or should I just see what happens?
After sitting for an extended period, it will need to run a while with some fresh oil to free up the rings before attempting a compression test, otherwise you are subject to getting an inaccurate test result. That's about the only way unless you plan to rebuild it during the initial restoration in which case no test is necessary anyway.
