new harness
macibell111
new harness
Post by macibell111 »
just put my new harness in all good except for the dim blackout lights and marker lights there is juice to them but they are very dim why is tis happening ,is it a weak ground,dont have the rear lights hooked up yet would that make a difference??
w30bob
Re: new harness
Post by w30bob »
Hi macibell,
You posted a while back about converting to a 12V system. Is that what you're talking about here? If so....did you change all the 24V bulbs to 12V bulbs?
macibell111
Re: new harness
yes that's me .evey bulb was changed to 12 volt,when I put them on a separate 12 volt power supply.they work fine.thought maybe a bad ground,one of my headlights was dim until I attached the ground it got brighter..thats why I thinks maybe the ground
tbone1004
Re: new harness
Post by tbone1004 »
If they got brighter with the ground you need to go and clean all of your grounding strap locations and make sure the battery terminals are nice and clean too.
That being said, switch to relays and you'll be so much happier and so will your wiring....
w30bob
Re: new harness
Post by w30bob »
Hi macibell,
Should be pretty easy to troubleshoot. Measure the voltage at each light, first with the grounds you have, then measure with respect to a known good ground, such as where the battery grounds to the frame.....or from the (-) terminal on the battery itself. Should tell you everything you need to know. :D
macibell111
Re: new harness
I will try that, thanks for the info guys much appreciated,will let u know soon,got sidetracked with taking off the bed.
