anthony manzella wrote:WELL HOW CAN I PUT IT H*LL I FOUND 2 BAD CYC #3&4 #3 is 20# and#4 is at10# hopefuly it's not going to be total rebuild but could use some good pointers I'am all eyes and ears
It is a possibility, but I'm not convinced your issue here is a blown head gasket. My reasoning is this, generally when a blown head gasket is the deal with 2 adjacent cylinders, the PSI reading for both is dead "0". A "0" reading for both is almost 100% certain blown head gasket. This being said, you need to verify that your test gauge is offering correct readings before you proceed. Since you have a 20 & 10 reading, that points more toward leaking (burned valves & seats) or severe ring/cylinder wall wear or damage. You can get a better idea of what may be going on using the following method, remove all spark plugs, individually put a tablespoon of engine oil in a plug hole & immediately re-test that hole for compression. Proceed with adding the oil to each plug hole 1 at a time & re-testing. If your PSI readings increase substantially after you added the engine oil, the problem is more concentrated to ring/ cylinder wall wear or damage. The oil will seal the rings temporarilly causing the compression to increase. If you see little or no change after adding oil & re-testing, this points to the valves being most of your problem. What were the readings on the other 4 cylinders? If they are at or below 100 PSI you are borderline, if they are below 90 PSI, forget it, a TOTAL rebuild is your only answer unless the 2nd test reveals the problem to be valves. Readings of 115 PSI or above with no more than a 5 PSI variation from 1 cylinder to another are considered acceptable to a good running engine. Lower readings are saying the engine is becoming tired & you need to be thinking overhaul in the not to distant future.
Let me add this, if by chance you find the head gasket to be the issue for cylinders 3&4 with good readings on the other 4 cylinders, don't think just replacing the gasket will fix the problem. There is an extremely high likelyhood that a low area in the head surface is the cause of the blow. Head gaskets don't blow for no reason when installed correctly on a flat surface. At the very least you would need to have the head resurfaced so it is perfectly flat before installing the new gasket.
If you will post the compression test result for each cylinder here for the original test & the new test after adding the oil, I can help you further with your diagnosis. Good luck.
