Transfer case question np200
fodman
Post by fodman »
Hi all, i need to know what the travel distance is that the shift rails move in and out when shifting the transfer case. i am working out of town and my wife at home wont crawl under my truck to measure :roll: . thanks for any help, fodman
jimmy_stikx
Re: Transfer case question np200
Post by jimmy_stikx »
Are you talking about the things the levers attach to? if so, mine look about an inch or so. I could measure the throw while I degrease the outside.
fodman
Post by fodman »
yes that is what i need,thanks fodman
i was going to offer up measuring my spare transfer case in my garage if nobody else responded. If you find you still need particulars, let me know.
fodman
Post by fodman »
yeah i still need the measurement, installing an airshift and i have to have that info to get the correct air cylinders. thanks fodman
Ok Fodman,
I can check that this afternoon and post the numbers.
A day late but here you go: both of my transfer case shafts moved 5/8 of an inch from full-in then out to the ball-stop.
fodman
Post by fodman »
Thanks for the info, just what i needed. fodman
Glad to help!
