Drag link dust cover
Gerry
Post by Gerry »
Whats the best way to close the dust cover tabs?
Gerry
53 M37
Re: Drag link dust cover
Not sure what you mean, Gerry. If the little metal straps aren't reaching the slots so you can bend them over, put a ratchet strap on the cover and cinch it up-that'll give you the length to run the strap thru the slot, then bend it back flat against the cover.
Gerry
Post by Gerry »
Gary,
Thats the ones I mean. The ratchet strap is a good idea. Needle nose to bend the tabs??
Gerry
53 M37
Gerry
Post by Gerry »
Got it.
Gerry
53 M37
Sure thing-glad it worked!
