Is there a tool or trick that makes closing the connectors easier? Working in a cold garage its a pain in the a$$ to close them.
Douglas connectors
Douglas connectors
Gerry
53 M37
53 M37
Re: Douglas connectors
It seems the first one I tried was the worst. I did a few more and they weren't as bad but a trick would still be great.
Gerry
53 M37
53 M37
Sand a bit off the ends of the butt connectors. Any large grit will do. The brown or white plastic types are the best. The black hard rubber (I think it's rubber, could be resin) type tend to be very brittle. I usually chuck them when I come across them. Sand and check the fit of the shells. Repeat until it only takes moderate effort to get them to lock.
Put a couple of chemical hand warmers in your pockets when doing the work that requires any sort of motor control. Ask me how I know
Dave Ostlund
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
- SSGT
I also had to trim down a few of the tubular connectors and used a pair of rubber-faced pliers to help twist together a few stubborn connections
1953 Dodge M43
Fail often to succeed sooner
- m37jarhead
If the shells are difficult to mate, be sure to use gloves. I didn't on some new shells and innerds.
I tried connecting new ones and the male shell with the tabs on it cut a pretty nice gash on my thumb. #@$*&#@ Duh!
Just short of needing stiches. Live and learn I guess.
JB
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
