Paint code for the standard OD
Sorry Knattrass but there are no true aerodynamics for an M37.  The vertical windshields, para-sail front fenders, etc. make the M a wind grabber for sure.  I mount my spare can with the spigot side to the rear but do not know if the TM indicates which direction it should face.
Gary.
							Gary.
No, I'd imagine what CG meant was that your jerry can holder is installed improperly. The tall surface w/ the 4 holes is supposed to face the truck instead of outward.knattrass wrote:CG - I'll assume that the wedge portion of the jerry can faces the front of the vehicle to improve the M37 aerodynamics and fuel economy?
John
NRA LIFE MEMBER
1954 M37 w/w
						NRA LIFE MEMBER
1954 M37 w/w
 Home
 Home
