Prop shafts
- HingsingM37
Prop shafts
Here is the first of many silly questions as I begin re-assembly. Which direction do the prop shafts go? Long side at the pumpkin or transfercase? Does it matter? When I took them off two years ago the short female yoke ends were at the transfer case side, but this looks different from a picture in one of my manuals?
Re: Prop shafts
The slip yokes ALWAYS go on the DRIVER end, or output yokes of the transfer case. The other or DRIVEN end attaches to the component that is being driven, in this case that is the differential yokes. The same is true on the intermediate shaft, the slip yoke attaches to the transmission ouput & the splined stub shaft to the transfer input.HingsingM37 wrote:Here is the first of many silly questions as I begin re-assembly. Which direction do the prop shafts go? Long side at the pumpkin or transfercase? Does it matter? When I took them off two years ago the short female yoke ends were at the transfer case side, but this looks different from a picture in one of my manuals?
- HingsingM37
Re: Prop shafts
Sorry - but I'm a bit slow todayMSeriesRebuild wrote: The slip yokes ALWAYS go on the DRIVER end, or output yokes of the transfer case. The other or DRIVEN end attaches to the component that is being driven, in this case that is the differential yokes. The same is true on the intermediate shaft, the slip yoke attaches to the transmission ouput & the splined stub shaft to the transfer input.
OK - now that I have my underwear on backwards.....
Drive Splined Shaft - long shaft with grooves - male shaft(3 diff lengths)
Slip Yoke - short stubby - female spline (3 all the same)
Slip Yokes - one connects to transmission output, one connects to RWD transfer case, one connects to FWD transfer case. I think these are the same part used in 3 locations looking at the manual.
Drive Shaft - long one connects to RWD pumpkin, med length one connects to FWD pumpkin, and the real short one attaches to the transfer case aimed at the transmission.
Yes?
Yes?
If I'm reading you correctly, this sounds right.knattrass wrote:OK - now that I have my underwear on backwards.....
Yes?
To add to this subject driveshaft alignment is important also, the slip yoke if removed, must go back on the same way so the u joint yokes on each end are inline to each other. Some slip yokes are keyed to only go that way, others are not allowing incorrect alignment and resulting in bad driveline vibration.
68 M-715 MVPA# 2710
All original M37 drive shafts have keyed splines, so unless you are dealing with a non-original replacement, you can't go wrong.
