speedometer cable routing
Gerry
Post by Gerry »
Can anyone tell me where in the manuals is the info on the cable routing or have a good picture showing it? Im pretty sure how it goes but I want to get it right.
Gerry
53 M37
Re: speedometer cable routing
I posted this one a while back-deals with the transfer case end only. The important thing is to have as gentle a bend as possible. My speedo works fine with the cable routed this way (as shaped in the photo).
http://www.g741.org/PHPBB/viewtopic.php ... ble#p37339
Gerry
Post by Gerry »
Gary,
Thanks for the reply. Thats how I have minr in the rear now I need to check the fire wall end.
Gerry
53 M37
WarrenD
Post by WarrenD »
I should be around Sat if you want to stop by for a look. Sunday I'll be in Hartford for the parade. I have a creeper, bring a flashlight!
Gerry
Post by Gerry »
Thanks Warren. I think i figured it out. I found another set of pictures i took during disasembly that showed it better. I probably will have a need at some point this winter as i put my cab together after finally getting her painted.
Gerry
53 M37
