Correct Motor Oil?
Tim Powell
Correct Motor Oil?
Post by Tim Powell »
Hey Crew.
At the risk of opening an old topic, who can tell me the proper, or at least the most recommended, type and weight, motor oil to put in our M-37 w/original motor.
I'm not a big "synthetic" Guy, but would consider it if that's what it takes??
W_A_Watson_II
Re: Correct Motor Oil?
Post by W_A_Watson_II »
Something with higher levels of zinc and phosphorus compounds, or add them vie an additive.
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
Tim Powell
I use "Mobile Delvac" 15 w 40 in the dually and I know they make a 1300 Super 10 w 30. I'll do some reading!! I believe it to be a good oil and I can but it local!! 10% discount if it's in stock!
What sort of additive do you like?
Stay away from that synthetic stuff, it will find every nook and cranny to leak out of, unless you have a fresh re-build!
Tuko
Post by Tuko »
ZDDPlus is a popular zinc additive that is most easily available on ebay. 1 bottle per oil change. I use it in my cummins (flat tappets) and the 51 also.
51 Dodge M37 W/W 4BT/NV4500
My G741 Registry Entry
WarrenD
Post by WarrenD »
I've been using Shell Rotella 15-40.
Tim Powell
OK Crew!
Thanks for all the tips! I've never really been a big synthetic fan simply do to the cost. (cheap-charlie)
I think I can get shell Rotella in our stores as well. I actually need to switch my fork-lift over so I can run one oil in everything.
I'll look for the additive as well.
snowdad
Post by snowdad »
Tim,
I plan on going with the Shell Rotella 15-40W in everything vintage thing I have. It is the most recommended in all the forums I have been a part of . Get the STP oil treatment in a blue plastic container. Look at the very fine pring on the front of the label. It says ZDDP. And you can get it at Wal--mart. Shell is what I have always used in the International 574 Diesel on the farm and will now use it in both 1954 Super A and the 1950's 200 Farmall.
WarrenD
Post by WarrenD »
I get the Rotella in Walmart.
Tim Powell
Hey Crew!
First of all "Thank You" for shopping at Wal-Mart! Most of you know that's who I drive for. They have been very good to me for the past 10 years. I'm actually a truckdriver with a life!!
Next. I thank you all for the tips! I ran into a bit of a situation with my oil filter, but Charles and I are doing extensive research on that issue! I'll let you all know what we find out.
It seems Wix has two filters that are the same physical size other than the gasket, but wait until we determine this to be true 100%.
snowdad
Post by snowdad »
Should be Wix 51100. I just hit 2 great deals on e***. First got 4 filters for $4.99 each plus 10.00 shipping and this morning got 6 for $29.96 and free shipping so will have a nice stock for a while.
Tim Powell
Re: Correct Motor Oil & Correct Filter!!
Congratulations Snow-Dad. You are correct on the Wix number.
After much research and comparison here are my findings.
When I removed the oil filter from my truck it was marked Wix 51006. It was in there and it was working. (just barely)
The Wix # 51006 comes with 2 cover gaskets. The larger of the 2 will fit loosely in the cover and might not leak. (mine did not)
The Wix # 51100 comes with one cover gasket and is noticeably "heavier-duty" and fits the cover much tighter!!
Both filter cartridge canisters are identical but the Wix #51100 comes with the correct heavy-duty gasket for the M-37.
NAPA Gold 1100 is also the correct filter and gasket.
Many "Thanks" to Charles Talbert for the help as well!
Sal
Post by Sal »
Be careful when buying oil filters on line. I use WIX filters in my truck also and wrote them a while back about the life span of a unused filter and this is what they had to say....
Question : IS THERE A SHELF LIFE FOR UNUSED OIL FILTERS?
Answer : 5 years
The Paper in the filter will get brittle and should not be used if it's 5 years old or older.
Thank you for your interest in WIX® Filters.
Question/Request:
IS THERE A DATE OF MANUFACTURE PRINTED ON YOUR OIL FILTERS, AND HOW DO I READ IT. I HAVE ONE OF YOUR #51100 FILTERS IT HAS NUMBERS ON IT BUT I CANT MAKE HEADS OR TAILS OUT OF IT. CAN YOU HELP ?
On most filters there will be in small print a number like this 062111ab1
This is simply a date = 06 - June , 21 - Day , 11 - Year , ab is usually the plant it was made in and 1 is the shift.
Hope this Helps
Sal
1954 M37 WO/W
1969 M101A1
snowdad wrote:Should be Wix 51100. I just hit 2 great deals on e***. First got 4 filters for $4.99 each plus 10.00 shipping and this morning got 6 for $29.96 and free shipping so will have a nice stock for a while.
Cha-Ching! Nice catch snowdad, are you going to open a on-line store front or do the bricks & mortar thing? :wink:
Tim, You are always opening a can of worms or something or another? :lol:
Tim Powell
Hey Bruce!!
I try to be a good little truckdriver but then, well, you know the rest of the story!! :twisted:
Extra fine job from Sal!! Great intel.
