How to test gauges on the dash panel??
m37jarhead
Post by m37jarhead »
My water temperature gauge is not working.
Where do I find the information on how to test
gauges and sending units??
Any help appreciated.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
WarrenD
Re: How to test gauges on the dash panel??
Post by WarrenD »
When you say it's not working, how is it not working? Needle points to coldest temp and doesn't move, pegged at highest or jumps around? I tend to replace the gauge first and if that doesn't do it, then replace the sender.
Sal
Post by Sal »
Is this what your looking for I got it from Cuz.
http://www.cj3a.info/sibling/milgauge/milgage.htm
Sal :mrgreen:
1954 M37 WO/W
1969 M101A1
m37jarhead
Warren: The gauge is dead. No movement when turning ignition on or turning or off.
New wiring harness with new "spyder".
Oil pressure gauge and battery generator indicator gauge work fine.
Tried another old, questionable temp. gauge. No change.
Thanks to Sal for testing info.
Thanks to Cuz for posting.
JB
Past Pres
Member: MVPA #26600
Member: NRA
m37jarhead
Sal:
Pegged at coldest temp and does not move.
Will start test proceedures early a.m. tomorrow.
Test results to follow.
Past Pres
Member: MVPA #26600
Member: NRA
Sal
Post by Sal »
I found the easiest way to trouble shoot this problem was to remove the wire going to the sending unit , ground and turn on the ignition while your in the cab, If the gauge goes fully to the hot side this tells you the wire and gauge are working and the problem should be on the sending unit side.
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
m37jarhead
Replaced the temp gauge with one from an M series deuce. 120 to 240 degrees
Old gauge is 60 to 260 degrees.
When cold the new gauge does jump a little when the ignition is turned on.
When engine is hot, the gauge is pegged full right at 240.
Does that mean the sending unit is probably working?
Have not had a chance to run Sal's test yet this morning or
the proceedures from Cuz.
Back out in the heat to see what I can find.
JB
Past Pres
Member: MVPA #26600
Member: NRA
