Its naked!
Its naked!
Went to go pick up my frame and cab from the sandblaster today and got a few pictures! Got to talking to him and hes going to take on the painting of it as well for a bit more money. I was going to pay someone to do it since I dont have the space or know how to do it correctly and things just fell into place nicely. He is also going to do a bit of body repair that I was not going to do such as that hole in the cowl you can see in the picture. The patch was covered in a bunch of layers of OD so must have been done by the Army at some point so I was just going to put the patch back on but it will be repaired. It will come back home painted and ready for reassembly, cant wait to see it with the new paint!
Re: Its naked!
Very nice, I can't wait to see more pictures.
Re: Its naked!
looking good. clean looking cab i cant even see the common pitting along the lower door seal. here on the wet coast i see a lot of rust.
i noticed you have the rear shock mounts still on your truck. have you taken them off ? i have seen rust jacking between the shock mount and the frame. my buddy's truck was so bad by the time we knocked off the scale, less than half of the original frame thickness remained. i noticed that on the backside of the shock mount there is a nice pocket for water and salt to sit. an easy fix with a file.
Re: Its naked!
SMART IDEA TO PAINT IT RIGHT AWAY AFTER SANDBLASTING. EXPOSED IRON IS SO PRONE TO RUST BY MOISTURE IN THE AIR!!! I HAVE SEEN IT HAPPEN TO FRESHLY SANDBLASTED ITEMS. PLUS YOU ARE DONE WITH THE BULKY ITEMS TOO. NICE WORK
- HingsingM37
Re: Its naked!
Looks good. Enjoy the rebuild. Thanks for sharing the pics!
Re: Its naked!
Im very fortunate to have started with a truck that spent its life after the service down on a ranch near pheonix Arizona. No rust, no stuck bolts, no dings/dents. Cant wait to see it wearing its new paint!
Re: Its naked!
i wish i was so fortunate. the truck im currently restoring was siliconed up. every seam and hole was filed with silicone. the previous owner even undid all the rivets on the frame and siliconed all the frame brackets on. every seam with silicone has matching rust jacks
